AutoCAD 2010/2011/2012
Valued Mentor
16 Kudos
Post 1 of 5
Layer Control" display
287 Views, 4 Replies
01-31-2013 07:18 AM
At the top of my screen, I have the "Layer Control".
Until this week, if I clicked on a line, the layer the line is on is diplayed in the "Layer Control".
If I wanted to know which layer an item is on, I just click on it and its layer would be displaye.
If I wanted to change the layer an item is on, I just click on it, then go to the "Layer Control", scroll thru the list, click on the layer I want.
This week, the "Layer Control" just shows the Current Layer.
Did I change a setting?
Read Ya Later -KLYPH
Maybe your PICKFIRST is set at ZERO, try 1.
601 Kudos
Post 2 of 5
Re: Layer Control" display
01-31-2013 07:20 AM in reply to: KLYPHY
Valued Mentor
16 Kudos
Post 3 of 5
01-31-2013 07:39 AM in reply to: Patchy
That was it. I normally have is set to "1", but somehow it became set to "0".
Thanks. Read Ya Later -KLYPH
263 Kudos
Post 4 of 5
01-31-2013 07:51 AM in reply to: KLYPHY
Hello
Just an idea ...
Command: LAYER
Then in the left part (Filters) of the Layers dialog box, please check that you are displaying ALL Layers
Close
Is it ok ?
Bye, Patrice
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
502 Kudos
Post 5 of 5
01-31-2013 03:23 PM in reply to: KLYPHY
Chances are you have some customization or third-party additions present with either no or very basic error handling.  When a tool is called it changes the system variable temporarily, does its work, then (if all goes well) restores the previous value.  If it errors out part way through it doesn't restore the previous setting and you're left holding the empty bag.  If you've ever had the FILEDIA issue, its the same priniciple.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
