AutoCAD Forum
join problem
6 REPLIES 6
645 Views, 6 Replies
join problem
any idea why arc and lines in the attached file will not join ?
pedit join fails both in normal and multiple mode , including activating fuzz and add line option . all points coordinates have z = 0  .
6 REPLIES 6
I suspect pedit will refuse arcs created from a 3d geometry , which is probably the case here .
replacing arcs one by one does work , but i hope theres a quicker way
nestly2
Polylines can exist only in a single plane.  The curved section was apparently created in a different UCS than the straight sections.  LIST command displays the Extrusion direction for that object as
Extrusion direction relative to UCS:
                   X=    0.000  Y=    0.000  Z=   -1.000
in reply to: nestly2
strange that a 2d object has an extrusion direction . i still think it has to do with 3d to 2d conversion .
that will have to be modified in a routine , since it does not appear in properties or quickproperties.
thanks.
SEANT61
It is available via the Filter command.  With that, perhaps the pertinent objects can be selected and Mirror3D'd (delete source object = Yes)
May your cursor always snap to the location intended.
in reply to: SEANT61
seant61 thanks  . I found this small routine  which uses that command
It will select all objects with a Z=-1 extrusion and 3d mirror them .
(defun c:swap (/ f1 )
(setq f1 (ssget "_x" '((210 0.0 0.0 -1.0))))
(if
(/= f1 nil)
(command "_mirror3d" f1 "" "_xy" "0,0,0" "_y")
(setq f1 nil)
(princ)
SEANT61
That looks perfect.
”Boost
