AutoCAD 2010/2011/2012
Distinguished Contributor
cajohnsen
Message 1 of 5 (923 Views)
Isometric drawings for plumbing risers
923 Views, 4 Replies
03-13-2013 06:33 AM
How do I change the crosshair so it is at an isometric angle for drawing?
Craig
*Expert Elite*
Patchy
Message 2 of 5 (917 Views)
Re: Isometric drawings for plumbing risers
03-13-2013 06:39 AM in reply to: cajohnsen
F1, type in Isometric.
F5 to select face.
*Expert Elite*
Bob_Zurunkle
Message 3 of 5 (857 Views)
03-14-2013 09:30 AM in reply to: Patchy
On the command line -- snap --> style --> isometric
Or snap style standard for coming out of isometric into standard mode.
Try making a custom button for each one!
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
cajohnsen
Message 4 of 5 (837 Views)
03-14-2013 12:47 PM in reply to: cajohnsen
It did work.
Can you give an idea on how to make a custom button.
Craig
*Expert Elite*
Bob_Zurunkle
Message 5 of 5 (808 Views)
03-15-2013 09:30 AM in reply to: cajohnsen
Sur. TYpe CUI to open the Customizable User Interface. Scroll down to any command, right-click on one, duplicate it and then rename it. The info to the right shows the line of command text for the original command -- this is what you replace with your own. A hint is that a space and a semi-colon both work as "carriage returns" (same as hitting the <enter> key). You have to test out the syntax a few times to see if it executes the command in your workspace. For this one you have to repeat the command to turn snap spacing off after changing from one style to the other. To test it you have to throw it on a toolbar or Ribbon Panel in your workspace.
The last bit of fun is to take the button image and edit it to create your own original (remember to save it). :-)
Post to the Community
New Post
Need installation help?
