AutoCAD Forum
Is there a tool to insert graphic scale into paper space w/Autocad 2012?
3 REPLIES 3
db_2014
14757 Views, 3 Replies
I keep seeing these graphic scale images in the drawings:
Is it something that I can insert from a tool in Autocad that will scale automatically with a viewport, or do I need to draw it myself (manually)?
3 REPLIES 3
3wood
in reply to: db_2014
You have to draw it manually.
sthompson1021
Type TP at the command line. That should bring up the tool pallet. Click on the annotation tab and you should see a block for imperial grapic scale.
Click on that block and then insert it in the dwg. It is a dynamic block so when select it you can click on the arrow and choose the scale you want.You will have to manualy scale it to the size you need.
db_2014
in reply to: sthompson1021
Appreciate it. Works great. Only if they connected it to the actual scale of the viewport 🙂 But otherwise works nicely.
”Boost
