AutoCAD 2010/2011/2012
TNFergus
Message 1 of 2 (348 Views)
Is the old double click dim editor really gone ?
348 Views, 1 Replies
10-24-2011 10:35 AM
Hi, I am new to ACAD '11 and I am really missing the old editor that pops up when you double click a dimension.
It's not just a text editor (ddedit)... it's the one where you can change the "geometry" of the dim... (change arrowheads, remove lines, etc.).
When the window popped up it had 3 tabs across the top.
I hate using the properties window for all this.
If anyone remembers this... and knows how to add it to my ACAD 2011... I would really appreciate the help.
If anyone does have the answer... a simplified version would be great... I'm a relative dummy when it comes to editing anything inside ACAD's CUI, etc.
Thank you very much
TNFergus
Message 2 of 2 (335 Views)
Re: Is the old double click dim editor really gone ?
10-24-2011 11:16 AM in reply to: TNFergus
Couldnt edit a 2nd time...so I replied to my post...
I am thinking it was an "AutoCAD Mechanical" feature, after doing a bit of Googling...
Maybe I'm just out of luck.
Attached is an image I found of the "Geometry" window...
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
