AutoCAD 2010/2011/2012
Member
acoury
Message 1 of 15 (10,733 Views)
Invert Crosshair Color in AutoCAD 2011
10733 Views, 14 Replies
11-24-2010 10:57 AM
Is there a way to make the cross hairs default to the inverse of the color under them (e.g. black when over white, blue when over yellow, cyan when over red, etc.)? I remember that it did this in previous versions, but I can't find a setting for it in 2011.
*Pro
nestly
Message 2 of 15 (10,728 Views)
Re: Invert Crosshair Color in AutoCAD 2011
11-24-2010 11:10 AM in reply to: acoury
Normally, "white" crosshairs will automatically invert to "black" if the background is white, and vice versa, but I believe they'll aways default to "black" if you try to set them the same color as any other background color. You can obviously make your crosshairs any color you want, but I don't ever recall them automatically switching to contrast non-standard background colors.  If this is something you do frequently, perhaps you could make a profile for each color scheme.
Message 3 of 15 (10,708 Views)
11-24-2010 01:33 PM in reply to: acoury
Works the same as in older the versions here, aka color inversed like you mentioned. I use white xhair on black background.
Member
acoury
Message 4 of 15 (10,612 Views)
11-30-2010 02:42 PM in reply to: acoury
My crosshairs are set to white in model space (black background), and they turn black in paper space (white background). But they don't change color depending on what is behind them. I was working with a drawing with a lot of white solid hatches, and my crosshairs weren't visible on top of the hatch. It was pretty frustrating. It sounds like it's not a version thing. I wonder where the setting is.
Active Contributor
cadhelp
Message 5 of 15 (10,384 Views)
01-04-2011 10:16 AM in reply to: acoury
AutoCAD -> Options -> System -> Performance Settings -> Manual Tune -> Enable Hardwere acceleration : Uncheck
neaton
Message 6 of 15 (10,379 Views)
01-04-2011 10:25 AM in reply to: acoury
Options/Display/Colors... will bring up the dialog box to change the colors of the cursor. I have my cursor set to 140 so I can see it easily on the black and white backgrounds. My problem was losing it in paperspace.
Nancy
Active Contributor
cadhelp
Message 7 of 15 (10,372 Views)
01-04-2011 11:10 AM in reply to: neaton
There is always a hatch or solid with odd color, that will block the crosshair
Will INVERSE (make it opposite color here) crosshair in Paper or Model space.
Member
acoury
Message 8 of 15 (10,368 Views)
01-04-2011 11:13 AM in reply to: acoury
Disabling hardware acceration did the trick. Thanks!
neaton
Message 9 of 15 (10,345 Views)
01-04-2011 12:37 PM in reply to: acoury
Okay, that has to be one of the most obscure places to effect crosshair performance! Couldn't imagine why hardware acceleration would change the cursor color. Thanks, cadhelp.
Nancy
Member
acoury
Message 10 of 15 (10,339 Views)
01-04-2011 12:48 PM in reply to: neaton
I agree. It seems like they should be able to include this in the crosshair color options. I hope disabling hardware acceleration doesn't negatively impact performance.
