AutoCAD 2010/2011/2012
New Member
licensing
Message 1 of 4 (957 Views)
Installation failure-Win7 64 with Autocad Electric 2010
957 Views, 3 Replies
04-20-2012 08:51 AM
I have one workstation that gets 3/4 of the way through a network installation point of autocad and then I watch the installer reverse itself and uninstall.  This installer has worked on other win 7 64 bit computers.  I vaguely remember there's some pre-requisites that if they're not there the install will fail.  I installed dot net 3 and 4, do I need to slam dot net 1 and 2 on also.
Or are there other common "you'd better have THESE" pre-requisites for installs to work.  The event log has not provided much help in terms of pointing me in a direction.  On the other workstation I had six months ago it was adding dot net but right now I don't remember the particulars.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 4 (929 Views)
Re: Installation failure-Win7 64 with Autocad Electric 2010
04-20-2012 11:04 PM in reply to: licensing
For 2010 you should have installed 3 and 3.5 (including servicepacks and languagepacks, if available).
Upload the log-file here, maybe for someone else it's a help to identify whats happening.
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Member
jstrowe
Message 3 of 4 (870 Views)
04-24-2012 09:38 AM in reply to: licensing
Here's the log, I see a few errors but nothing that tells why it's failing and rolling back
2012/4/19:09:16:32    testuser    testuser-8540    === Setup started on testuser-8540 by testuser ===
2012/4/19:09:16:32    testuser    testuser-8540    Launch
2012/4/19:09:17:22    testuser    testuser-8540    === Setup ended ===
2012/4/19:09:16:33    testuser    testuser-8540    === Setup started on testuser-8540 by testuser ===
2012/4/19:09:16:33    testuser    testuser-8540    Launch
2012/4/19:09:17:22    testuser    testuser-8540    Installing Autodesk® Design Review 2012:  TRANSFORMS="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\x86\en-us\Components\adr2012\SetupDesignReview2012-autocad-2012-64.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/19:09:19:07    testuser    testuser-8540    Install    Autodesk® Design Review 2012    Succeeded
2012/4/19:09:19:07    testuser    testuser-8540    Installing DirectX® Runtime: \\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/19:09:19:52    testuser    testuser-8540    Install    DirectX® Runtime    Succeeded
2012/4/19:09:19:52    testuser    testuser-8540    Installing Autodesk® Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/19:09:20:14    testuser    testuser-8540    Install    Autodesk® Material Library 2012    Succeeded
2012/4/19:09:20:14    testuser    testuser-8540    Installing Autodesk® Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/19:09:21:17    testuser    testuser-8540    Install    Autodesk® Material Library 2012 - Low Resolution    Succeeded
2012/4/19:09:21:17    testuser    testuser-8540    Installing Autodesk® Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/19:09:22:19    testuser    testuser-8540    Install    Autodesk® Content Service    Succeeded
2012/4/19:09:22:19    testuser    testuser-8540    Installing AutoCAD® Electrical 2012:  TRANSFORMS="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\x64\en-us\acade\acad.mst;\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\x64\acade\acad-autocad-2012-64.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" INSTALLDIR="C:\Program Files\Autodesk\Acade 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/19:09:33:35    testuser    testuser-8540    Install    AutoCAD® Electrical 2012    Failed    Installation aborted, Result=1603
2012/4/19:09:33:54    testuser    testuser-8540    Rollback    Autodesk® Content Service    Succeeded
2012/4/19:09:34:07    testuser    testuser-8540    Rollback    Autodesk® Material Library 2012 - Low Resolution    Succeeded
2012/4/19:09:34:23    testuser    testuser-8540    Rollback    Autodesk® Material Library 2012    Succeeded
2012/4/19:09:34:23    testuser    testuser-8540    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2012/4/19:09:34:37    testuser    testuser-8540    Rollback    Autodesk® Design Review 2012    Succeeded
2012/4/19:09:34:41    testuser    testuser-8540    === Setup ended ===
2012/4/20:10:47:03    testuser    testuser-8540    === Setup started on testuser-8540 by testuser ===
2012/4/20:10:47:03    testuser    testuser-8540    Launch
2012/4/20:10:48:11    testuser    testuser-8540    === Setup ended ===
2012/4/20:10:47:05    testuser    testuser-8540    === Setup started on testuser-8540 by testuser ===
2012/4/20:10:47:05    testuser    testuser-8540    Launch
2012/4/20:10:48:11    testuser    testuser-8540    Installing Autodesk® Design Review 2012:  TRANSFORMS="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\x86\en-us\Components\adr2012\SetupDesignReview2012-autocad-2012-64.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" INSTALLDIR="C:\Program Files (x86)\Autodesk\Autodesk Design Review 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/20:10:49:58    testuser    testuser-8540    Install    Autodesk® Design Review 2012    Succeeded
2012/4/20:10:49:58    testuser    testuser-8540    Installing DirectX® Runtime: \\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\3rdParty\DirectX\DXSETUP.exe /silent
2012/4/20:10:50:50    testuser    testuser-8540    Install    DirectX® Runtime    Succeeded
2012/4/20:10:50:50    testuser    testuser-8540    Installing Autodesk® Material Library 2012:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/20:10:51:14    testuser    testuser-8540    Install    Autodesk® Material Library 2012    Succeeded
2012/4/20:10:51:14    testuser    testuser-8540    Installing Autodesk® Material Library 2012 - Low Resolution:   ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/20:10:53:01    testuser    testuser-8540    Install    Autodesk® Material Library 2012 - Low Resolution    Succeeded
2012/4/20:10:53:01    testuser    testuser-8540    Installing Autodesk® Content Service:  INSTALLMODE=PRIVATE AUTOSTART=0 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/20:10:54:15    testuser    testuser-8540    Install    Autodesk® Content Service    Succeeded
2012/4/20:10:54:15    testuser    testuser-8540    Installing AutoCAD® Electrical 2012:  TRANSFORMS="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\x64\en-us\acade\acad.mst;\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\x64\acade\acad-autocad-2012-64.mst" MSINEWINSTANCE=1 ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="\\Rochester-f02\MIS\Installs\autocad2012-64\AdminImage\" INSTALLDIR="C:\Program Files\Autodesk\Acade 2012\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/4/20:11:04:11    testuser    testuser-8540    Install    AutoCAD® Electrical 2012    Failed    Installation aborted, Result=1603
2012/4/20:11:04:31    testuser    testuser-8540    Rollback    Autodesk® Content Service    Succeeded
2012/4/20:11:04:46    testuser    testuser-8540    Rollback    Autodesk® Material Library 2012 - Low Resolution    Succeeded
2012/4/20:11:05:01    testuser    testuser-8540    Rollback    Autodesk® Material Library 2012    Succeeded
2012/4/20:11:05:01    testuser    testuser-8540    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2012/4/20:11:05:10    testuser    testuser-8540    Rollback    Autodesk® Design Review 2012    Succeeded
2012/4/20:11:05:17    testuser    testuser-8540    === Setup ended ===
Product Support
VinodBalasubramanian
Message 4 of 4 (863 Views)
04-24-2012 05:50 PM in reply to: jstrowe
1603 is more of a generic permissions error. Can you confirm whether you are trying to install the product as an administrator. Also try turning of UAC in the control panel under User accounts while trying to install the product.
Can you please try these suggestions and let us know whether it helps or not,
http://forums.autodesk.com/t5/Installation-Licensing/Autocad-2011-Installation-trouble-error-1603/td...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=6549582&linkID=9242018
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=10310469&linkID=9240617
Hope it helps.
Vinod Balasubramanian
Announcements
Need installation help?
