AutoCAD 2010/2011/2012
p1k
New Member
0 Kudos
Post 1 of 4
Installation Autocad after uninstal
2686 Views, 3 Replies
09-17-2012 02:44 PM
I have uninstalled autocad 2010 because i was not anymore able to open autocad. I got a splash screen wich closed direct after it opend. Or I got a popup "Unable to load AcDb resourse file". I have followed the instructions  on this site to solve this problem without results.
I tride to do a new installation but while trying i get a mesage "autocad 2010 is already installed your computer".
There are 3 dll files left on my computer and an empty folder. First is C:\Program Files\Common Files\Autodesk Shared\AcSignCore16.dll
Second is  C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcShellExtension.dll Third is  C:\Program Files\Common Files\Autodesk Shared\AcShellEx\AcSignCore.dll And the fourth is  Netwerk\MyPC\Autocad 2010Share . The last one is an empty folder wich I cannot open. (0Kb)
All those files I cannot remove
How can I instal my Autocad 2010 again?
Thanks for your solution.
Thanks for this info.
In the mean time I have found an other solution.
Microsoft has a clean up utility that should allow you to remove blocked programs and clean up the registery.
http://support.microsoft.com/mats/Program_Install_and_Uninstall
I have let it run on my computer and after that I was able to instal Autocad 2010 again.
So my problem is solved.
Thanks again.
1,219 Kudos
Post 2 of 4
Re: Installation Autocad after uninstal
09-17-2012 02:53 PM in reply to: p1k
Start your Windows in safe-mode (when Windows is start to boot press <F8> to get the option). Then there are only a limited number of services running and so these files are not locked.
- alfred -
Alfred NESWADBA
p1k
New Member
0 Kudos
Post 3 of 4
09-18-2012 06:18 AM in reply to: p1k
Thanks again.
New Member
0 Kudos
Post 4 of 4
10-10-2012 01:05 PM in reply to: p1k
Alison
This solution is for 2010, not 2013. Does this apply to 2013 as well?
Does 2013 need this four files?
The Microsoft Fix ask if I am having a problem installing or uninstalling software. I am doing neither.
The one thing Microsof Fixt shows I have two verions of AutoCAD 2013 installed. Is one for the MEP Version?
I have two install logs.
AutoCAD 2013 Install.log.
AutoCAD 2013(en-us)Install.log
I would attach but they both exceed the file size limit.
