Hi Everybody,
i'm having problems with something that i've done a few times before and that allways worked out perfectly fine.
I am trying to use the "Insert Field" command within a Mtext object. The Object sits on paperspace and is suppossed to to show the title of the layout.
Logically i use "CurrentSheetTitle" - but somehow i only get ####.
Regen, changing layouts, restart doesn't work.
fieldeval was set to 31, now is 16 - doesn't make any difference.
Any ideas?
Greetings alex
Solved by steven-g. Go to Solution.
