AutoCAD 2010/2011/2012
Active Contributor
s.i.g.-koch
Message 1 of 2 (310 Views)
insert blocks
310 Views, 1 Replies
07-13-2010 07:53 AM
is it normally by opening a new drawing from autocad 2010 in form of a *.dwt- file, that in every drawing is an block on first position:
AEC-grips_none?
Valued Mentor
wengle
Message 2 of 2 (279 Views)
Re: insert blocks
07-13-2010 06:05 PM in reply to: s.i.g.-koch
AEC? Isn't that architectural? If you are in the correct forum (autocad and not architectural), the answer is: No, that is not "normal".
If, on the other hand, you ARE using autocad, then start a New dwg (dwt), make any changes you want to it and save as acad.dwt in the Template folder.
Announcements
Need installation help?
