AutoCAD 2010/2011/2012
Member
mdigrigoli
Message 1 of 9 (971 Views)
INSBASE PROBLEMS (locked)
971 Views, 8 Replies
08-01-2012 08:12 AM
Hi there, we are having problems with some files at the office where the insbase of an xref is locked and will not change by inserting in the command line INSBASE and then 0,0,0. Instead the values remain locked to a random coordinate, so the only way we have to change it back is by moving the actual xref grabing it by the point that's supposed to be in 0,0,0 and then inserting the destination coordinate as 0,0,0. This is becoming a problem as xrefs get moved and it's time consuming to correct it, not to mention the confusion among everyone that work on the files on daily bases. Could anyone shed a ray of light to this problem please!
*Expert Elite*
Charles_Shade
Message 2 of 9 (967 Views)
Re: INSBASE PROBLEMS (locked)
08-01-2012 09:12 AM in reply to: mdigrigoli
Have you gone through the exercise via the pop up windows and made sure that the Insertion Point option is unchecked and the Coords are all set to Zero?
Please mark any response as "Accept as Solution" if it answers your question.
_____________________________________________________________
Regards, Charles Shade            Win8 FAQ
CSHADEDESIGN|AUTOCAD LT|LT-KB|DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted.
Member
mdigrigoli
Message 3 of 9 (961 Views)
08-01-2012 09:30 AM in reply to: Charles_Shade
what do you mean by the pop-up windows? where? What I have tried is in the command line inserted INSBASE and then tried to change from there, but as I mentioned the values seem to be locked at a ramdom coordinate and once I try to change them to 0,0,0 nothing happens
*Expert Elite*
Charles_Shade
Message 4 of 9 (957 Views)
08-01-2012 09:35 AM in reply to: mdigrigoli
Type XREF from the Command line and you should have an XREF Palette Open.
Click the Drawing tag in the upper left and choose a Drawing File.
This will open another window with options there just as Insert has.
Look for the Insertion Point here.
What version of CAD do you have?
There may be better options in the specific Forum.
Member
mdigrigoli
Message 5 of 9 (946 Views)
08-01-2012 09:44 AM in reply to: Charles_Shade
oh ok, yes my insertion point is always 0,0,0. So I have no idea what's happening...it's the first time I post in the forum so I don't really know where I should post. I usually find the solution to my problems just by doing a search, but this time it seems nobody has the same problem! Thanks for your help...
Member
mdigrigoli
Message 6 of 9 (945 Views)
08-01-2012 09:46 AM in reply to: Charles_Shade
BTW I have version 2011, but this happend to us also on 2010, we just upgraded about two weeks ago
*Expert Elite*
Charles_Shade
Message 7 of 9 (937 Views)
08-01-2012 10:49 AM in reply to: mdigrigoli
Are the units the same for both files? Target and XREF?
Does the XREF file come from you or outside the office?
Glad you came here to check and see about a solution.
Usually start in the Forum for your product and if need be get directed somewhere else.
mikeharris17
Message 8 of 9 (881 Views)
08-04-2012 08:03 AM in reply to: mdigrigoli
Try going into your xref, type BASE and set to 0,0,0.
Valued Mentor
KLYPHY
Message 9 of 9 (847 Views)
08-07-2012 08:21 AM in reply to: mdigrigoli
Also check and see if your UCSs are the same.
When inserting, I like to use the World UCS in both locations.
Read Ya Later -KLYPH
Announcements
Need installation help?
