AutoCAD 2010/2011/2012
Active Member
dougy_8505
Message 1 of 8 (395 Views)
in school and need help figuring out something...
395 Views, 7 Replies
09-28-2012 10:59 AM
Ok i have been using autocad 2012 for some time now so i end up getting ahead of my teacher, well i created 2 drawings according to the book we are using, but he decided he wanted the drawings done in MM instead of Inchs, so i was wondering if there is a way to covert my drawing from inch to MM?
M_Hensley
Message 2 of 8 (391 Views)
Re: in school and need help figuring out something...
09-28-2012 11:23 AM in reply to: dougy_8505
If the units drawn represent inches you can use the SCALE command and scale up all your objects by 25.4 to make them represent millimeters.
dgorsman
Message 3 of 8 (390 Views)
09-28-2012 11:25 AM in reply to: dougy_8505
You could use the SCALE command to change the size of everything, but in the real world thats like hitting it with a sledgehammer.  You will end up with odd-numbered sizes which is usually discouraged; most things need to be built and those in the field work faster with 1000mm instead of 1016mm.  Certain manufactured objects are constructed and/or labelled differently in metric units than they are in imperial units so may not even be available in the that converted size.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Active Member
dougy_8505
Message 4 of 8 (380 Views)
09-28-2012 11:54 AM in reply to: dougy_8505
ty guys
JDMather
Message 5 of 8 (349 Views)
09-29-2012 04:42 AM in reply to: dougy_8505
Are you to change the physical size or only the units of the dimensions?  If you only need to convert the inch dimensions to equivalent size metric dimensions - that is pretty easy to do in the dimension styles.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
Bob_Zurunkle
Message 6 of 8 (291 Views)
10-05-2012 09:12 AM in reply to: JDMather
...or you start a new drawing with a metric template, copy and paste the imperial one into the metric one, find a known metric dimension, then scale the whole thing by reference to the new dimension...
If by some odd chance my nattering was useful -- that's great, glad to help. But if it actually solved your issue, then please mark my solution as accepted :smileyhappy:
Distinguished Contributor
Kazo
Message 7 of 8 (221 Views)
10-10-2012 06:57 PM in reply to: Bob_Zurunkle
Perfect answer Bob!
Bob_Zurunkle
Message 8 of 8 (200 Views)
10-11-2012 09:26 AM in reply to: Kazo
10-Q Boyce! :smileyvery-happy:
