Hey there
im trying to make some 3d spline gears in autocad, i start by generating them in eMachineshop then importing into autocad, this works fine but the gear is imported as seperat lines so i cant extrude them, i also cant join the lines because after zooming in there are quite a few gaps. anyone know how i can join the lines together withought manually connecting the dots? ill include a copy of the gear, eMachineshop only outputs dxf files as far as i know.
Solved by hmsilva. Go to Solution.
Welcome to the Autodesk Community, owen
Try the pedit command, multiple option, join option with some fuzz...
HTH
Henrique
