AutoCAD 2010/2011/2012
Member
outcastc
Message 1 of 7 (1,154 Views)
Importing excel table autocad entities
1154 Views, 6 Replies
02-21-2012 02:35 AM
hi. i want to import my excel table to autocad. but when i try to do this, the table is not corretcly import. im using paste special command and past to link. if i paste my file excel, image and other formats, i can not plot my draw. i attach my excel file.
note: i found a software that name is autotable. but its 150$. we dont want to buy an other software.
sorry for my english thanks
*Expert Elite*
pendean
Message 2 of 7 (1,146 Views)
Re: Importing excel table autocad entities
02-21-2012 05:23 AM in reply to: outcastc
Plotting to what? Using what driver?
What does "not correctly imported" mean?
Seems to work just fine here, see attached and a PDF print test.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
outcastc
Message 3 of 7 (1,138 Views)
02-21-2012 07:15 AM in reply to: outcastc
have you red my post correctly? i dont want to import excel file copy and past. i want it to autocad entities (which is written on subject). look attached file. it created with an addon software
*Expert Elite*
Patchy
Message 4 of 7 (1,127 Views)
02-21-2012 08:08 AM in reply to: outcastc
My English is BAD too but I can see your question as you wanted to PLOT the excel when it pasted into your Autocad.
"i want to import my excel table to autocad. but when i try to do this, the table is not corretcly import. im using paste special command and past to link. if i paste my file excel, image and other formats, i can not plot my draw. i attach my excel file."
*Expert Elite*
pendean
Message 5 of 7 (1,121 Views)
02-21-2012 08:21 AM in reply to: outcastc
Your add-on may be the problem then: attached is your file and a PDF print of it, works fine here. If there are errors in your table, I don't have the time to read each line, you will have to describe the problem better.
So what are you plotting to that it does not work? Your posts remain light on details.
Member
outcastc
Message 6 of 7 (1,102 Views)
02-21-2012 11:55 PM in reply to: pendean
sorry for my bad english. if i past excel file to my draw it seems good and good seen print preview. but when i try to plot it  (i mean print my draw)  with hp designjet 500 plotter and its failing. excel file is not printing. only lines and draws printing. after that i found an addon and import excel file printing successfully done.
note: im printing minimum 4mt draw with scale (ex:4000x450 mm, 8257x620 mm etc.). because of this i dont create pdf file. i can not meausure and scale my draw in pdf.
so my question is how i can import attached excel file correctly (like addon makes) using past special command and choosing autocad entities.
my plotter has 192mb ram.
*Expert Elite*
pendean
Message 7 of 7 (1,090 Views)
02-22-2012 06:57 AM in reply to: outcastc
Your HP500 driver may be the problem, nothing else: test on your end by plotting to PDF and DWF (which can be set to output full size as you wish), and test on other printers.
If needed, you can print the PDF or DWF to your HP500 driver while you wait for someone to offer a fix for your HP500.
Announcements
Need installation help?
