Hi!
I have got troubles with Union command.
I am trying to use union for 2 objects and I receive the following message
Select objects: Specify opposite corner: 36 found
Select objects:
At least 2 solids, surfaces, or coplanar regions must be selected.
Solved by nestly2. Go to Solution.
The fins are a Polar Array, which much be EXPLODEd back into individual solids before they may be UNIONed.
