When i was woking with autocad 2010 suddenly Autocad went down and it stucked my computer. So i restarted it and then i opend my previus work. All the work has been saved bu in the window i couldn't see tools on it. Actually tools are there and i can use them. but i cant see them. you cn see it your own by the following snap i've taken.
I repaired and then i reinstalled it too.. but the problem is there. and also the problem is only with the classic view. Hope you'll help me with this. And I'll be Thankfull if you coud solve this.
Solved by nestly2. Go to Solution.
Thank you for the solution and I appreciate your contribution on this forum.
The second method ( Restoring the Cui) Worked for me.
Thank you very much..
