AutoCAD 2010/2011/2012
Active Contributor
0 Kudos
Post 1 of 12
I can't print dwg to Adobe PDF
4031 Views, 11 Replies
05-01-2012 06:10 AM
I can't print dwg to Adobe PDF. Printer drivers ale installed and work fine in other application. Onle in AutoCAD 2012 is some problem.
*Expert Elite*
1,210 Kudos
Post 2 of 12
Re: I can't print dwg to Adobe PDF
05-01-2012 06:30 AM in reply to: kjdrafting
It would be a help if you can give more detailed info. Out of your message ti could be:
  1. AutoCAD crashes
  2. PLOT-dialog does not start
  3. you have chosen the wrong printer.driver in the PLOT-dialog
  4. you get an empty PDF-file
  5. you don't get any file written
  6. you get a PDF-file, but you can't open it with a viewer
  7. you get a error message?
  8. ....and a lot more.
Where do we have to start?
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Active Contributor
0 Kudos
Post 3 of 12
05-01-2012 06:55 AM in reply to: Alfred.NESWADBA
After few minutes I got error message: devices not found
*Expert Elite*
1,210 Kudos
Post 4 of 12
05-01-2012 06:58 AM in reply to: kjdrafting
please show two screenshots, one showing the PLOT-dialog when you have all properties set ... and the other from this error-message.
BTW: Why don't you use the driver "DWG to PDF.pc3"?
- alfred -
Alfred NESWADBA
Active Contributor
0 Kudos
Post 5 of 12
05-01-2012 07:13 AM in reply to: Alfred.NESWADBA
Here you are!
*Expert Elite*
1,210 Kudos
Post 6 of 12
05-01-2012 07:34 AM in reply to: kjdrafting
With this settings you don't use the Adobe printer-driver.
In the PUBLISH-dialog you have set PDF as output (top left of the dialog and that uses the "DWG to PDF.pc3"-output. Sometimes it helps if you create this PC3 file from scratch or you copy it from another computer.
You can also try to verify the printer-config by starting a PLOT command for a single layout and use this PC3-file.
Good luck, - alfred -
Alfred NESWADBA
Active Contributor
8 Kudos
Post 7 of 12
05-02-2012 05:08 PM in reply to: kjdrafting
The "DWG to PDF" plotter comes with your installation of AutoCAD whereas selecting "Adobe PDF" to plot an AutoCAD dwg means you have Adobe Pro software installed on your computer as well.  Were you able to make pdfs of AutoCAD dwg files before you installed Adobe Pro on your computer?
When I PUBLISH, I do not use page setup overrides; I either plot using the output device saved in each tabs' page setup, or I import a page setup from a separate AutoCAD dwg file.  This works from my computer, which has both AutoCAD and Adobe Pro installed on it.  Even though I have both pdf distillers in my plotter list, I only save DWG to PDF in my page setups.
Out of curiosity, I've attached an old file (minust its xref) with the page setup set to DWG to PDF.  Try publishing this without overriding the page setup and see if this might produce pdfs for you.
Clara
"A common mistake that people make when trying to design something completely foolproof is to underestimate the ingenuity of complete fools."
Product Support
18 Kudos
Post 8 of 12
05-08-2012 04:32 PM in reply to: kjdrafting
Hi kjdrafting,
Were you able to sort out the publish problem you were having?
Bryce Thelin
New Member
0 Kudos
Post 9 of 12
02-02-2013 06:17 PM in reply to: kjdrafting
hey alfred. you can possibly help me. i actually dont get any file written when i try to create a pdf form autocad. What can i do to fix that?
*Expert Elite*
461 Kudos
Post 10 of 12
02-03-2013 02:41 PM in reply to: rmc0018
This setting can be found a few places in AutoCad.
1. Publish (see post #5 of this thread) Publish Options>Prompt for file Name setting.
2. Within Sheet Set Manager options.
3. In the .pc3 file itself which can be opened by right clicking on the pc3 in windows explorer to access the options.
What is likely happening is the pdf is being created and because "prompt for file name" isn't enabled it creates the pdf and is placing it in the default pdf output folder.
Jay
Jay
C3D 2014 SP2
Win 7 Professional 64 Bit
Post to the Community
New Post
