First sorry for my bad english, because I'm using an online translator.
I have a series of drawings in the company who have a plethora of text styles. Due to the large amount autocad locks the entire command.
I would like to find a way to drain these styles which are apparently attached to the drawing.
Have deletes everything that was in one of them trying to find out the source of the styles of texts, but they do not leave the drawing.
I appreciate if anyone knows how to do.
If a text style is in use anywhere in the file, it can't be purged.
EDIT: You'll be please to know that the English translated just fine. 🙂
Don Ireland
Engineering Design Technician
you have not only a lot of textstyles, you also have a lot of linetypes, Try the DGNPurge utility (>>>from here<<<) and hopefully that is a help.
I tried it with your drawing, after DGNPURGE and then a normal _PURGE the filesize was reduced to 43kB (using AutoCAD 2014)
- alfred -
