Three years ago I created a drawing in which I inserted Hyperlinks into the drawing. When I made a PDF from the drawing the Hyperlinks were still there and worked correctly from the PDF. Not sure which version of AutoCAD this was created from. I am now using 2012 and have tried to repeat the process but when I create the PDF the Hyperlinks are not there. Please can you advise.
Did this ever get an answer? I have tried a direct export from AutoCAD 2014. I have printed a pdf from design review using Adobe Acrobat XI Pro... no luck. Apparently I need a preset called Rich Content Pdf, which I can't find anywhere. I have tried to print using the latest and greatest bluebeam, downloaded a trial this morning. No luck. I have complained to everyone I can think of that Autodesk does not provide a dwf reader for the Mac OS or IPad that isn't some form of 360 and tried to remind Autodesk that not all construction sites have web access. Dwfx's work great but without the Mac version it is a challenging sell.
Thank you for the reply. Sometimes I feel that Autodesk is ashamed of dwf's... anyway I have been trying to print a pdf without loosing the links and can't do it. I have been looking for the Rich Content Pdf preset from Adobe but can't find it and am not able to get the hyperlinks to come out with Bluebeam either. Does anyone know what is in the hyperlink/pdf magic sauce?
FYI. This is possible in 2017 for sure and I believe in 2016 as well. If you select the DWG to PDF.pc3 plotter, there is a new "PDF Options..." button. Make sure "Include hyperlinks" is checked.
From DWG to DWF to PDF does not work either.. .
See here the dwf hyperlink does work, but then to PDF it does not work..
Some special options i need to use?
Its neccesary to convert/print the pdf file through the publishing tool. So you need to print/publish more than one plan. Select the group of layouts and with the right mouse button click and go to the (publish selected layouts). then you can enter in the publisher where you can see on the right part publisher options... theis is the way you have to print in order to get the hyperkinks in your pdf file.
