What I only did was to insert an XREF, then hundreds of linetypes were loaded, I don't need them and it's very annoying trying to find out my linetypes in hundreds of them.
Can anyone help me?
Solved by Patchy. Go to Solution.
Solved by braudpat. Go to Solution.
Hello
You are facing to the DGN LineTypes Bug/Probem !
*** AutoCAD DWG files unexpectedly increase in file size ***
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD...
*** ACAD 2015 PURGE ***
http://knowledge.autodesk.com/support/autocad-lt/troubleshooting/caas/blog/withoutanet.typepad.com/w...
If you can share with us your DWG (in ZIP format please) somebody can filter/purge/clean your "bad" DWG !?
Patrice BRAUD
Hi Pat,
Now I'm having the same problem but with AutoCAD 2015. Do you know how to get rid of hundreds of linetypes charged in my program?
R4sso
