AutoCAD Forum
Hundreds of linetypes
4 REPLIES 4
R4sso
319 Views, 4 Replies
What I only did was to insert an XREF, then hundreds of linetypes were loaded, I don't need them and it's very annoying trying to find out my linetypes in hundreds of them.
Can anyone help me?
4 REPLIES 4
rkmcswain
in reply to: R4sso
Can you open the XREF and purge them out?
What version of AutoCAD is this?
Do the linetype names look like the first few as seen here?
http://bit.ly/11QUiOz
braudpat
in reply to: R4sso
Hello
You are facing to the DGN LineTypes Bug/Probem !
*** AutoCAD DWG files unexpectedly increase in file size ***
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/AutoCAD...
*** ACAD 2015 PURGE ***
http://knowledge.autodesk.com/support/autocad-lt/troubleshooting/caas/blog/withoutanet.typepad.com/w...
If you can share with us your DWG (in ZIP format please) somebody can filter/purge/clean your "bad" DWG !?
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
R4sso
in reply to: braudpat
Hi Pat,
Now I'm having the same problem but with AutoCAD 2015. Do you know how to get rid of hundreds of linetypes charged in my program?
R4sso
Patchy
in reply to: R4sso
”Boost
