i have received a file*.dwg (please see the attached file), there is a xref (the name is:OAImg2129231416_EMBED) embedded in this file. I can see it from my autocad 2010, but why i can not print it out in paper or in pdf?
thank u for the help!
I can print it to PDF, as it's an image (and not a referenced DWG) sometimes it depends on
Look to my PDF and let us know your system specs + AutoCAD release to continue supporting.
- alfred -
Thank you, i use a plain Autocad 2010. My system is Windows 7, 64 bits. My RAM is 4 G.
How could i print this file to pdf file like you?
Thank you very much!
To be honest, running a 64bit OS with just 4GB of memory? That might be the reason as it's the (absolutely) minimum of memory.
I just printed to the "DWG to PDF.pc3" driver with default settings, as you are low in memory you might try that settings for your systemvariables in AutoCAD:
RASTERTHRESHOLD ==> increase to 1000 (max 2000)
RASTERPERCENT ==> increase to >50 (max 100)
At least this will reserve some amount of memory, but to be safe please first save your working files before starting plot then as that might reserve more memory than available.
HTH, - alfred -
