AutoCAD 2010/2011/2012
Active Contributor
jason75
Message 1 of 5 (265 Views)
How to use -Insert
265 Views, 4 Replies
02-25-2014 05:08 PM
I am trying to write a script and I need some help.
I need to inset a block using -insert. Then i need to specify a file path and then the block name.
File path: svr\access\test\revision
Block name
P2.scr
-insert C:/svr/access/test/revision/p2 0,0 1 1 0 Assumptions: the file is on your C drive, if not use the correct one. The block is named P2, if not substitute for the correct one. Insertion point is 0,0, scale of X and Y is 1, rotation is 0.
pendean
Message 2 of 5 (238 Views)
Re: How to use -Insert
02-25-2014 08:36 PM in reply to: jason75
What do you type at the command line after you type -INSERT? Scripts are just that, what you can type and get to work at the commandline.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
doni49
Message 3 of 5 (216 Views)
02-26-2014 06:52 AM in reply to: jason75
As Dean said, a script contains the same thing you'd enter at the command line.  The simplest way to get what you need is to open notepad and acad.  Then do the first one manually and start entering the info into acad -- start with -insert.  Then everytime you press enter, type the same exact thing in notepad (every time you hit enter in acad, that belongs on a new line in notepad).  Then after you're done with the first one, you should be able to save and use your script file.
After that, if you still have issues, come back and ask.
Don Ireland
If a reply solves your issue, please remember to click on "Accept as Solution". This will help other users looking to solve a similar issue. Thank you.
Forum links:
AutoCAD 2013/2014/2015
AutoLISP, VB and other AutoCAD customization
Civil 3D General
Civil 3d Customization
Other Helpful links:
My File is too large to post or I can't post it due to privacy issues!
braudpat
Message 4 of 5 (209 Views)
02-26-2014 09:13 AM in reply to: doni49
Hello
You have written ---> File path: svr\access\test\revision
It could be --> File path: \\svr\access\test\revision
if \\srv is the hostname of your Server !?
Bye, Pat
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
GrantsPirate
Message 5 of 5 (192 Views)
02-28-2014 07:45 AM in reply to: jason75
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
