I am trying to write a script and I need some help.
I need to inset a block using -insert. Then i need to specify a file path and then the block name.
File path: svr\access\test\revision
Block name
P2.scr
Solved by GrantsPirate. Go to Solution.
As Dean said, a script contains the same thing you'd enter at the command line. The simplest way to get what you need is to open notepad and acad. Then do the first one manually and start entering the info into acad -- start with -insert. Then everytime you press enter, type the same exact thing in notepad (every time you hit enter in acad, that belongs on a new line in notepad). Then after you're done with the first one, you should be able to save and use your script file.
After that, if you still have issues, come back and ask.
Don Ireland
Engineering Design Technician
Hello
You have written ---> File path: svr\access\test\revision
It could be --> File path: \\svr\access\test\revision
if \\srv is the hostname of your Server !?
Bye, Pat
Patrice BRAUD
GrantsPirate
Piping and Mech. Designer
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
