AutoCAD 2010/2011/2012
JamaL9722060
Message 1 of 3 (177 Views)
Accepted Solution
How to show a set of particular layers (of the same drawing) in each lay out?
177 Views, 2 Replies
04-24-2012 03:01 PM
How to show a set of particular layers in each lay out?
I’m wondering if there is a way to turn off particular layers in a layout without affecting other layouts.
For example, in the screenshots below, if I need to show only “1_walls” layer in the layout “p_04” but to keep all other layers turned on in other lay outs, then how can perform this?
Thank you for the help
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
Yes.  While model space is active in your layout, drop down the layer list and click the third icon from the left.  It is titled 'freeze or thaw in curent viewport'.
Active Contributor
nvengineer
Message 2 of 3 (173 Views)
Re: How to show a set of particular layers (of the same drawing) in each lay out
04-24-2012 04:54 PM in reply to: JamaL9722060
JamaL9722060
Message 3 of 3 (153 Views)
04-25-2012 01:37 PM in reply to: nvengineer
Thank you for the help. Your answer has solved my issue.
Best
Jamal
Firefox 20.0,
Kaspersky 2013.
Announcements
Need installation help?
