AutoCAD 2010/2011/2012
Distinguished Contributor
0 Kudos
Post 1 of 8
How to redefine block base point?
17068 Views, 7 Replies
08-10-2011 03:50 AM
How can I change the location of the (base point) of a block without exploding it?
thanks
Open block in block editor. Use the parameter 'base'. Select your new base point. Save and close Tge editor
33 Kudos
Post 2 of 8
Re: How to redefine block base point?
08-10-2011 04:11 AM in reply to: jz4all
0 Kudos
Post 3 of 8
08-10-2011 05:13 AM in reply to: jz4all
Thanks for fast reaction.
In the illustration , the used command (CBI ) doesn't work.
And command (base) has nothing to do with block base point.
Any other suggestion?
33 Kudos
Post 4 of 8
08-10-2011 05:30 AM in reply to: jz4all
Did you try using CBIR?  There are two functions built into one lisp file.
0 Kudos
Post 5 of 8
08-10-2011 06:54 AM in reply to: jz4all
Actually I have no experience in lisp?
I would like to know if there is a regular command, or method in AutoCAD to do that?
33 Kudos
Post 6 of 8
08-10-2011 07:09 AM in reply to: jz4all
You typed CBI at the command prompt to run the portion that didn't work.  Now type CBIR at the command to try the second option of the lisp program.
If you don't want to use this program then create a new block in a separate drawing of your block with the same name.  Define the base point as you desire and then open the base file and insert the new block.  It will ask you if you want to redefine the old block.  Keep in mind that the block will probably shift in your base because of the different insertion point.
Active Contributor
3 Kudos
Post 7 of 8
08-11-2011 01:18 AM in reply to: jz4all
0 Kudos
Post 8 of 8
08-11-2011 02:16 AM in reply to: kevynm
Thanks, it works perfect.
