AutoCAD 2010/2011/2012
Active Member
pedroher
Message 1 of 14 (17,786 Views)
Accepted Solution
How to "flatten" a 3D model, to a just 2D line....
17786 Views, 13 Replies
11-18-2011 10:31 PM
FLATTEN doesn't exists, and when I try FLASTSHOT it asks me for digits and I really don't know what to type.......the ultimate goal is to make all my lines "FLAT" since in top view they look good but in 3D perspective some are just way up and down(non-flat)
>> _FLATTEN Unknown command "FLATTEN".  Press F1 for help
in this case:
>> If so ==> you just have to install Express-Tools
So start Windows control panel ==> programs and functions (or something similar) ==> AutoCAD ==> Add/Remove features
...and then you came to the installation-dialog, here you have the chance to make a check to "ExpressTools"
- alfred -
PS: sorry, I don't have an englisch operating system and also no english AutoCAD, so my description is using words of my translation! The may (and will) differ from the exact words.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 14 (17,781 Views)
Re: How to "flatten" a 3D model, to a just 2D line....
11-18-2011 11:36 PM in reply to: pedroher
What did you try? Put the word _FLATTEN in the command line, press <ENTER> and AutoCAD tells you that the command is not defined?
If not so ==> please describe why you think "FLATTEN does not exist"
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
*Expert Elite*
3wood
Message 3 of 14 (17,781 Views)
11-18-2011 11:45 PM in reply to: pedroher
You can try CHZ20.vlx if the objects are not 3dsolids.
3wood
CAD KITS
Valued Mentor
JohnHolder
Message 4 of 14 (17,755 Views)
11-19-2011 09:42 AM in reply to: pedroher
I have used <flatshot> alot
insert as a block and hit enter a few times.  I have never entered in any numbers just took the default.
An education isn't how much you have committed to memory, or even how much you know. It's being able to differentiate between what you know and what you don't.
"Do or do not... there is no try"
Master Yoda.
Active Member
pedroher
Message 5 of 14 (17,750 Views)
11-19-2011 10:42 AM in reply to: Alfred.NESWADBA
this is what it says when I input _FLATTEN or just FLATTEN....
Valued Mentor
JohnHolder
Message 6 of 14 (17,746 Views)
11-19-2011 10:45 AM in reply to: pedroher
Yes, have you installed the express tools as suggested ( when you get the unknown command )
Master Yoda.
Active Member
pedroher
Message 7 of 14 (17,745 Views)
11-19-2011 10:46 AM in reply to: JohnHolder
and FLATSHOT, for some reason is not selescting ALL of the lines, it only "flattens" what ever is a solid 3D, like my floor slabs........but I still have some lines that are in the z-axis
*Expert Elite*
Alfred.NESWADBA
Message 8 of 14 (17,743 Views)
11-19-2011 10:48 AM in reply to: pedroher
in this case:
- alfred -
Alfred NESWADBA
Active Member
pedroher
Message 9 of 14 (17,739 Views)
11-19-2011 10:50 AM in reply to: JohnHolder
where is that Express Tools for Autocad 2012? .... I saw few links about that express tools but were either broken links or for older versions of autocad, so I disregarded that option
Active Member
pedroher
Message 10 of 14 (17,736 Views)
11-19-2011 10:52 AM in reply to: pedroher
ok....let me check
Announcements
Need installation help?
