AutoCAD 2010/2011/2012
Active Contributor
0 Kudos
Post 1 of 8
How to print dwf file
2167 Views, 7 Replies
12-18-2011 02:04 AM
I want to print an existing dwf file to printer in a network programmatically with c# code. I tried acdbmgd.dll and acmgd.dll but i did not know which class and method should i use.
please help me...
>> Is there any way to print DWG file directly with c# code??
Yes, there exists a lot of code around the world, e.g. >>>this from Kean Walmsley<<<
- alfred -
look to the PC3-files you have plus the paper-sizes defined for each plotter. You can therefor start AutoCAD, open the _PLOT-dialog and there you have the info what is configured on your machine and so what's ready for use.
- alfred -
1,216 Kudos
Post 2 of 8
Re: How to print dwf file
12-18-2011 01:18 PM in reply to: M_Mogharabi
Hi,,
if you really mean DWF (and not DWG) then you should look either in the >>>forum for DesignReview<<< or, if the DWF is loadable in your Internet Explorer then you should look into the IE-lib for printing.
The acdbmgd.dll and acmgd.dll are AutoCAD-libs and are not used to print a DWF as long as you don't want to insert it into an AutoCAD-drawing and do a plot then from AutoCAD (what's a long way round).
- alfred -
Alfred NESWADBA
Active Contributor
0 Kudos
Post 3 of 8
12-18-2011 09:24 PM in reply to: Alfred.NESWADBA
Thanks alfred, first I have searched a week to find a way to print DWG file but i did not find anything and just i found some applications to convert DWG to DWF. so i thought that i should convert my DWG file to DWF and then print the DWF file.
Please help me...
1,216 Kudos
Post 4 of 8
12-19-2011 12:08 AM in reply to: M_Mogharabi
- alfred -
Alfred NESWADBA
Active Contributor
0 Kudos
Post 5 of 8
12-19-2011 02:10 AM in reply to: Alfred.NESWADBA
Thanks alot. however that code is for DWF files(not DWG files), so i should convert my DWG file to DWF before start to plotting it, am i right?
1,216 Kudos
Post 6 of 8
12-19-2011 02:38 AM in reply to: M_Mogharabi
No, not in the way you mean. The code shows how AutoCAD has to be used for plotting via C# (plot a DWG).
And that you think it's for DWF (because in the code the word "DWF" appears) ==>the code's result is a "plotted DWF-file", but you can change the code to plot to any other plotter, just set it to your plotter- (and page-) -properties.
- alfred -
Alfred NESWADBA
Active Contributor
0 Kudos
Post 7 of 8
12-19-2011 08:49 PM in reply to: Alfred.NESWADBA
ahaa... Thanks alot again. now i am got it. excuse me for my beginner questions, but it is the last one :
How can i change the plotter from file to printer? How should i change the string parameter of "SetPlotConfigurationName" method  to send my DWG file to printer?
1,216 Kudos
Post 8 of 8
12-19-2011 11:16 PM in reply to: M_Mogharabi
- alfred -
Alfred NESWADBA
