AutoCAD 2010/2011/2012
9 Kudos
Post 1 of 7
How to make the dimension get bigger and smaller as we “scale” the drawing?
9252 Views, 6 Replies
03-20-2012 12:11 PM
For example, the drawing in the screenshot below is scaled by 0.5 but that didn’t affect the “size” of the dimension (height of the text, extension lines, …).
Is there a way to get the dimension line affected as we scale the drawing such that the “dimension text” and the “extension line” are increased/ decreased with the scale factor?
Thank you for the help,
Best
Jamal
Jamal NUMAN, GIS and Civil Engineer, MSc
e-mail: JamaL9722060@yahoo.com
P.O.Box: 731, Ramallah, West Bank, Palestine.
Software: AutoCAD 2014, AutoCAD C3D, AutoCAD M3D, Revit
Windows 7 (Ultimate 64 bits),
Firefox 20.0,
Kaspersky 2013.
*Expert Elite*
61 Kudos
Post 2 of 7
Re: How to make the dimension get bigger and smaller as we “scale” the drawing?
03-20-2012 01:03 PM in reply to: JamaL9722060
Select those dimensions and change the DIm Scale Overall from the Property to 1/2 of what they are.
9 Kudos
Post 3 of 7
03-20-2012 01:17 PM in reply to: ToanDN
Thank you for the answer ToanDN. many thanks for the help.
best
Jamal
Firefox 20.0,
Kaspersky 2013.
*Expert Elite*
61 Kudos
Post 4 of 7
03-20-2012 04:02 PM in reply to: JamaL9722060
If you change universally from the dim style settings then you would need to create a new style or your future dims will all become half-size.  What I told you is only to override a certain dims.  Depends on your drawing, if you have a lot of half-sized dims then it may be worth while to create a new dim style.
*Expert Elite*
127 Kudos
Post 5 of 7
03-20-2012 11:00 PM in reply to: JamaL9722060
Yes, you can make the "size" of the dim in the model display differently if (1) you use an annotative dim style, (2) you change the scale setting of the model on the status bar, and (3) you map the scale to the dim.  But remember... this is only going to be this way in the model.  The purpose of annotative dimensions is to keep your text a consistent size in your plots.  So no matter how it looks here things will be the same in your plot as long as you use these scales in the viewport(s).
See the examples below.
Dave.
Dave Hein, P.E.
9 Kudos
Post 6 of 7
03-21-2012 09:50 AM in reply to: heinsite
thank you for the elaboration "heinsite". this is very useful.
best
Jamal
Firefox 20.0,
Kaspersky 2013.
9 Kudos
Post 7 of 7
03-21-2012 09:52 AM in reply to: ToanDN
Many thanks ToanDN.very much appreciated.
best
Jamal
Firefox 20.0,
Kaspersky 2013.
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
