AutoCAD 2010/2011/2012
Active Member
0 Kudos
Post 1 of 10
how to get the centerline symbol C/L
46365 Views, 9 Replies
10-21-2010 03:04 PM
how can i get the C/L sybol for centerlines.  i've tried everything.
*Pro
169 Kudos
Post 2 of 10
Re: how to get the centerline symbol C/L
10-21-2010 03:25 PM in reply to: regold53
Do you want a linetype with the symbol, or just the symbol in text?
http://screencast.com/t/1HGFiCJg
Distinguished Mentor
6 Kudos
Post 3 of 10
10-21-2010 03:48 PM in reply to: regold53
It's not available with standard fonts for autocad. I use a block that I made, which I can insert into a blank space in dtext or on the centerline of a column or circular object. At one time, many years ago, it was possible to use third party fonts, but no longer.
*Pro
169 Kudos
Post 4 of 10
10-21-2010 04:33 PM in reply to: wengle
Distinguished Contributor
7 Kudos
Post 5 of 10
11-11-2010 10:00 AM in reply to: nestly
In Mtext command select the @ symbol which drops down a menu.  Select center line.  Is this what you're looking for?
Lowell
Active Contributor
0 Kudos
Post 6 of 10
04-26-2011 11:45 AM in reply to: cadman70454
I have this issue too on some users systems in our office. It is a weird thing...
On most machines it works the way it is supposed to. We just use stadard AutoCAD fonts, mainly simplex and it works, but on some machines we open the same file where it worked and and it is a different font, ISOsomthing and we cant change it, but when we go back to the original machine it work
Where does AutoCAD pul the symbols? is it the font folder? or some font or character map?
Thanks in advance,
Randy
601 Kudos
Post 7 of 10
04-26-2011 11:59 AM in reply to: randoshadow
Type in FONTALT on the PC that doesn't show the symbol, what font does it say?
Active Contributor
0 Kudos
Post 8 of 10
04-26-2011 12:36 PM in reply to: Patchy
all PC come back with "simplex.shx"
I will also add, this only happens when we are using Civil 3D, when we open the files with vanilla autocad the centerline symbole comes out correct and the support paths are all the same
I think it might be a file issue or starting template issue, its just really weird and annoying.
Thanks for the help, I will troubleshoot a little more tonight after work and try to figure something out, maybe post some files tomorrow
312 Kudos
Post 9 of 10
04-26-2011 01:23 PM in reply to: regold53
check the dates of the simplex.shx that's being found and used on the dirrerent machines.  delete ALL the older ones, and copy in a fresh version from the install CD.  You're getting the ISO-font for the symbols because the version of the autocad shx file is an archaic version that does not have unicode characters.
New Member
4 Kudos
Post 10 of 10
07-19-2011 03:41 PM in reply to: regold53
Type \U+2104 in the text field.
