AutoCAD Forum
How to draw segment elbow 90 degrees and create Flat Pattern ?
7 REPLIES 7
Message 1 of 8
ASAJE
4347 Views, 7 Replies
Good Morning,
Just a quick confirmation please, We are a fabrication company however this particular job requires 2 No 90 Deg elbows to suit Dia. 800mm ducting. Because the bends are not available we intend to "roll" 4mm plate to suit the elbow as a facetted unit.
However my concern is we need to supply our profilers with the correct flat pattern for us to roll. Therefore can someone confirm the dimensions/conclusion I have attached are correct?
Thanks in advance,
Alan Stewart
7 REPLIES 7
Message 2 of 8
Kent1Cooper
in reply to: ASAJE
I don't believe they are:
I think [without analyzing too deeply] that the shape of the edges will be a form of a sine curve.
Kent Cooper, AIA
Message 3 of 8
ASAJE
in reply to: ASAJE
Kent,
Thanks for coming back to me. This is what I was concerned about and unfortunately I don't have modelling skills/capabilities to try it and see how it turns out.
I'm awaiting a response from a local engineering workshop for a response as they will model it in Inventor or similar.
Alan
Message 4 of 8
GrantsPirate
in reply to: ktsaleej
I followed the link in post 4, 90° bend, generated the lisp file, copied it and loaded in 2020, had the flat pattern in a matter of less than a second.  Very nice.
GrantsPirate
Piping and Mech. Designer
EXPERT ELITE MEMBER
Always save a copy of the drawing before trying anything suggested here.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
Message 5 of 8
lovecraft
in reply to: ASAJE
GP, I don't see the post (#4?) you're referencing here.  Can you supply this link?  This flat pattern generating lisp file sounds pretty cool.  Thanks in advance.
LC 🙂
Message 6 of 8
ktsaleej
in reply to: lovecraft
Message 7 of 8
lovecraft
Thanks for that, sir....will have to study this a bit more to determine how I might use this routine.
LC 😃
Message 8 of 8
Sea-Haven
Tried it out very nice not sure what the <br> is just removed.
”Boost
