AutoCAD 2010/2011/2012
Member
fa22ous
Message 1 of 8 (8,070 Views)
Accepted Solution
How to convert AutoCAD 3D draws to g-codes??
8070 Views, 7 Replies
02-04-2013 06:58 AM
Actually I need a help to convert my 3D AutoCAD draws into g-codes by using a CAM program maybe? The main issue is I bought a CNC machine which is based on Linux EMC2 and I'm not familiar with writing g-codes to run the machine,
the company suggested to use a CAM program to create g-codes after reading my 3D AutoCAD draws..
If it is possible, I need to know what program to use for such purpose and how to get it and use it with integration to Linux EMC2
Thx for concern,
Firas Eid
There are many CAM software packages.
MasterCAM is one.
*Expert Elite*
JDMather
Message 2 of 8 (8,055 Views)
Re: How to convert AutoCAD 3D draws to g-codes??
02-04-2013 07:57 AM in reply to: fa22ous
MasterCAM is one.
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Member
fa22ous
Message 3 of 8 (8,046 Views)
02-04-2013 08:10 AM in reply to: JDMather
Plz can you illustrate more or how it works?? I mean my 1st PC has the AutoCAD draw let us say, and the CNC machine PC has the Linux EMC2.. so where to download the master CAM?? and how we transfer the draw ??
Thx again for your help
Valued Mentor
martti.halminen
Message 4 of 8 (7,996 Views)
02-05-2013 12:17 AM in reply to: fa22ous
*Expert Elite*
JDMather
Message 5 of 8 (7,966 Views)
02-05-2013 10:23 AM in reply to: fa22ous
Download (and pay for) the MasterCAM software from the MasterCAM website.
Install on the Windows PC.
Get training on how to use the MasterCAM software.
Save the resulting g-code file in appropriate format (my guess would be *.txt) to take to the CAM machine.
Member
fa22ous
Message 6 of 8 (7,957 Views)
02-05-2013 01:16 PM in reply to: JDMather
thx a lot I appreciate ur help
New Member
mark2150
Message 7 of 8 (7,018 Views)
07-21-2013 09:25 PM in reply to: fa22ous
I've written an AutoCAD DXF to G-Code converter. It's still in beta - 1.0, and I'd like everone's opinion of it.
You draw on the DRILL layer and donuts are plunge drills, circles are circles, lines are cuts, etc.
Its ONLINE so there is no need to install ANYTHING on your system. Simply go to Docs for the instructions and Online Tool
There are sample .DXF and G-Code files you can use and screen snaps from MACH3.
If you have any questions or comments email me on Yahoo at madmark2150@yahoo.com and I'll try to answer ASAP.
The online version has been tested with my old copy of Acad 2000 and works great. It should work on other versions as well.
Any and all feed back welcome - ENJOY!
/s/
MadMark!
klemen.zivkovic
Message 8 of 8 (715 Views)
09-18-2014 04:41 PM in reply to: mark2150
How would I write inventor rule to output g codes from 3d object like rectangular pipe that needs to be angulary cutted on cnc plasma at the end of the pipe?
Is there any command to project all four faces of pipe to up, down, left and right plane from the code?
Than generate 4 dxf-s from that and than gcodes? Is there any clever way to do it?
Post to the Community
New Post
Need installation help?
