AutoCAD 2010/2011/2012
Member
joaovascor
Message 1 of 7 (200 Views)
How to convert annotation into points?
200 Views, 6 Replies
05-19-2012 11:39 AM
Hello, i have an elevation point layer that i'm using in a project and i needed to import it to arcgis for some interpolation.
Problem is, all altimetric points are "B"s instead of being points, and arcgis doesn't recognize them as points. Is there a way of quickly converting them all of them into points?
Take into consideration that we're talking about hundreds, maybe thousands of said "B"s.
Thank you very much
*Expert Elite*
Patchy
Message 2 of 7 (199 Views)
Re: How to convert annotation into points?
05-19-2012 11:57 AM in reply to: joaovascor
Attach the file, let's see.
Member
joaovascor
Message 3 of 7 (190 Views)
05-19-2012 02:29 PM in reply to: Patchy
Here goes. I think its a conversion from a DGN file, and one other thing, the maximum file size is quite small, so i had to cut almost 90% of this first file, so i have about 100 times what i show you on this file.
Thank you
*Expert Elite*
Patchy
Message 4 of 7 (186 Views)
05-19-2012 02:45 PM in reply to: joaovascor
Like this?
*Expert Elite*
Patchy
Message 5 of 7 (184 Views)
05-19-2012 02:48 PM in reply to: joaovascor
Or this
Member
joaovascor
Message 6 of 7 (151 Views)
05-20-2012 04:29 AM in reply to: joaovascor
It's exactly that! How did you do it?
*Expert Elite*
Patchy
Message 7 of 7 (141 Views)
05-20-2012 07:48 AM in reply to: joaovascor
I used different Autocad (LDD) to do it
But you can do the same thing by using this
http://forums.autodesk.com/t5/Visual-LISP-AutoLISP-and-General/Insert-Block-at-Text-Insert-Point/m-p...
Announcements
Need installation help?
