AutoCAD 2010/2011/2012
gmalone12
Message 1 of 3 (1,230 Views)
How to choose what CTB file Is used when you publish a sheet set?
1230 Views, 2 Replies
07-08-2011 01:10 PM
I am trying to PDF multiple sheets, but instead of doing them individualy I want to do they through the publish feature. Only problem is when I do it my lines come out way to bold becuase it is not using the .CTB file I want. I can't find the option on the publish settings, How do I do this?
Thanks in advance!!!!
You will specify the CTB in a pagesetup along with any other settings, so you will create a pagesetup to plot to pdf and use that as the override for all drawings you have listed in publish.
GrantsPirate
Message 2 of 3 (1,219 Views)
Re: How to choose what CTB file Is used when you publish a sheet set?
07-08-2011 03:12 PM in reply to: gmalone12
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
gmalone12
Message 3 of 3 (1,192 Views)
07-09-2011 07:13 AM in reply to: GrantsPirate
Thanks Man!
