AutoCAD Forum
how to change the color of an object according to another object
1 REPLY 1
257 Views, 1 Reply
Hi
i want to change the color or the layer of one text object (Text A) according to another text (Text B). That is to say, if i change the color or the layer of the Text B, i want the Text A change the color or the layer also.
Is it possible to do this? thank you!
Tags (2)
1 REPLY 1
nestly2
If two or more similar objects are to be displayed the same, then shouldn't they just be on the same layer to begin with?
Otherwise perhaps make them a GROUP.  (however changing the layer of one object in a group ultimately results in them all being on the same layer... thus same result as above)
”Boost
