AutoCAD 2010/2011/2012
Active Member
0 Kudos
Post 1 of 4
How save a layer so it won´t be editable in the copy?
228 Views, 3 Replies
07-08-2012 11:10 PM
I work in a multi-layer map, which I want to make a copy of. At the moment my background map (x-ref in layer 0) is editable/possible to unlock, but I don´t want it to be in my copy. Basically, I just want it to use it as a background picture in my new map.
Thankful for all hints! / Göran
No way in AutoCAD alone.  If you really want this, you must use something like CADlock.  You can make your background into a pdf and attach that but it won't be a drawing anymore.
But you could also plot that background out as a DWF and underlay that.  It also won't be an editable drawing file anymore but will respond like one more than a PDF will.
Dave.
190 Kudos
Post 2 of 4
Re: How save a layer so it won´t be editable in the copy?
07-09-2012 05:25 AM in reply to: GoranKLensmeden
127 Kudos
Post 3 of 4
07-09-2012 11:51 AM in reply to: dbroad
Dave.
Dave Hein, P.E.
Active Member
0 Kudos
Post 4 of 4
07-09-2012 10:49 PM in reply to: GoranKLensmeden
Thanks for the quick replies! I think it´ll work, now.
