I can't figure out a way to get rid of this message when opening a drawing. Not sure what software was used that this message comes from.
Solved by dtucker. Go to Solution.
What happens if you save the file - do you continue to get the message on next openings?
It keeps happening after saving the drawings. It was the system variable DWGCHECK. It was set to 1 to notify me. I changed the setting to 0 and the message goes away.
Thanks for your help.
