AutoCAD 2010/2011/2012
Member
glewis
Message 1 of 2 (72 Views)
How do we use Vault with an outside vendor that controls a large ‘master layout’
72 Views, 1 Replies
05-25-2012 10:25 AM
How do we use Vault with an outside vendor that controls a large ‘master layout’ directory of AutoCAD drawings that is given to us each week by way of FTP? How do we update the files in vault without having to check out dozens of files or folders then copy the new files (which often have missing xrefs that have to be fixed before Vault will accept them) into the working directory then check back in the files. This is way too time consuming and complicated to do on a weekly basis.
            The simplest procedure we can think of looks like this:
1)     Download new set of drawings.
2)     Open these drawings in AutoCAD reference manager to fix/remove broken xrefs so Vault will accept them.
3)     Check out the entire folder that needs to be updated from Vault
4)     Paste the new drawings over the drawings in MyDocs\Vault\Vendor
5)     Check all the drawings in through Vault, solving any vaulting issues that may have been missed in the reference manager.
Any help would be great.
*Expert Elite*
pendean
Message 2 of 2 (63 Views)
Re: How do we use Vault with an outside vendor that controls a large ‘master lay
05-25-2012 11:19 AM in reply to: glewis
VAULT has it's own support forum if you want to also try there:
http://forums.autodesk.com/t5/Autodesk-Vault/ct-p/2004
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Post to the Community
New Post
Announcements
Are You Going To Be @ AU 2014? Feel free to drop by our AU topic post and share your plans, plug a class that you're teaching, or simply check out who else from the community might be in attendance. Ohh and don't forgot to stop by the Autodesk Help | Learn | Collaborate booths in the Exhibit Hall and meet our community team if you get a chance!
