When I publish files I want to go to recent places on my computer. So I add the file path to the "add places item" dialog box. It adds it for that one session. When I publish something else it has gone away. Is there a way to permanently add a place on the publish file location list? Thank you.
Solved by rkmcswain. Go to Solution.
The places bar should be saved between AutoCAD sessions. Isn't this the same places bar you see when you use OPEN or SAVEAS? If you use one of those commands and add your folder there, does it show up when you publish?
If you want/need to dig deeper, this page will show you where the places bar entries are stored in the registry.
Yes it is the same places bar. When I add it to open or save it does not show up on the next opening of Autocad. I am using Autocad LT, sorry for not stating that in the beginning. Does that change anything?
I have come to a solution thank you very much. I followed that link and used the registry editor and copied the recent places link address into the place holder I wanted. Thank you again.
