I am working with a situation that requires me to block some lines underneath some text, and can't use a background mask because the text is located within a block. I tried to use wipeout, but I don't want the boundries of the wipeout to plot. Is there a way to set the boundries to not plot? I have tried changing the color of my wipeout object to 255, but for some reason I was unable to get that to work (I think that has to do with how my company uses plot styles to handle colors). Any ideas?
This sounds like what I need, but how do I access this option? I don't see it in properties, and I don't see it listed in setvars.
Nevermind, problem solved. You have to press "F" after entering the command, and it will give you the option to change the variable at that point.
