I have several drawings that encouter a problem with the dimstyle.
A dimstyle name STANDARD$0 is added by a mysterious reason, however it is hidden.
When i open dimension style I get a dimstyle name Standard and the dimstyle STANDARD$0, with both having different properties.
The problem is that when I make an annotation while selecting the dimstyle Standard I will make a new annotation with the properties of STANDARD$0.
The dimstyle STANDARD$0 can not be selected when I annotate, so the dimstyle is probably hidden.
I tried the command DIMOVERRIDE, but this didn't work. It failed already when I typed the dimstyle to override: STANDARD$0.
I tried to rename STANDARD$0 tot STANDARDtest and this worked. The properties of Standard where used in stead of STANDARD$0.
However, I can not select STANDARDtest from the annotation menu.
Is this a Hidden dimstyle or something? And how does this enter the dimension style. Can this occur while copying from other drawings?
No I don't see anything strange at the layers.
I think that might be the problem. But how do these dimstyles get attached?
