HI,
I normally plot my dwg files to pdf in AutoCAD. My plot style is set to “monochrome.ctb”
Most of the time in my drawing is there hatches with yellow color or cyan. When printing with monochrome.ctb I get a gray effect from these color and black stays black.
The problem I have now is that, when I plot using monochrome. It turns all my line and hatch colors to black. I do not have the gray effect any more.
Can someone help me with a solution to get the gray effect ?
Thank you
Solved by amudhaauroform. Go to Solution.
okay i have to change my plot style to monochrome but where do i change that? where can i change it to monochrome.ctb? is it a command?
Look in the PAGESETUP dialog box, and/or the PLOT dialog box. The plot style is in the upper right of both. If you don't see it in the PLOT dialog box, use the arrow icon in the lower right to expand the Plot dialog.
