AutoCAD Forum
Help generating a dwg file to a 1:1 ratio
1 REPLY 1
fishautodesk124
343 Views, 1 Reply
My original drawing was drawn to a 1:1 ratio but now when I measure the distance it comes to a delta x,y which is incorrect.
Can someone help me fix this so that my drawing will be back to the true distance that I had from the begining.
Windows 10 Professional Pro
Intel(R) Core(TM) i7-6700 CPU @ 3.4 3.41 GHZ
16 GB
64-bit Operating System x64-based processor
AutoCAD Civil 3d 2016 sp 4
1 REPLY 1
Murph_Map
in reply to: fishautodesk124
Sounds like you need to expand the command line to show more info. Either grap the top of the command line and drag it up to display 3-4 lines or press the F2 key after you check the distances of something.
Murph
Supporting the troops daily.
”Boost
