My original drawing was drawn to a 1:1 ratio but now when I measure the distance it comes to a delta x,y which is incorrect.
Can someone help me fix this so that my drawing will be back to the true distance that I had from the begining.
Solved by Murph_Map. Go to Solution.
Sounds like you need to expand the command line to show more info. Either grap the top of the command line and drag it up to display 3-4 lines or press the F2 key after you check the distances of something.
