AutoCAD 2010/2011/2012
Member
kahmeng_tan
Message 1 of 6 (1,571 Views)
Helix for spiral coils
1571 Views, 5 Replies
08-24-2011 10:31 PM
hi all,
I am trying to draw a flat spiral coil in 2D using the helix function but as soon as i use the 'flatten' command the coil becomes wiggly. is there a way to avoid this or do I have to use a different method to get a smooth spiral coil?
Perhaps I can increase the number of vertices so it looks smoother?
Thanks in advance.
Valued Mentor
parkr4st
Message 2 of 6 (1,565 Views)
Re: Helix for spiral coils
08-25-2011 03:15 AM in reply to: kahmeng_tan
did you use a height of zero?
dave
Member
kahmeng_tan
Message 3 of 6 (1,561 Views)
08-25-2011 04:14 AM in reply to: kahmeng_tan
Yes i did. Just a slight update to the problem, i need actually to REDUCE the number of vertices as the laser machine im feeding into has a maximum number it can take. How do i do this?
JDMather
Message 4 of 6 (1,544 Views)
08-26-2011 05:31 AM in reply to: kahmeng_tan
So let me get this straight.
You did use height of 0 to get a spiral (not a helix).
You are using Flattten to convert the spline curve to arcs for g-code?
If this is what you are doing I have the solution around on how to control the number of arcs, but before trying to dig deep I want to make sure of the problem description.
Autodesk Inventor 2015 Certified Professional
Inventor Professional 2015-SP1 64-bit
vladimir.michl
Message 5 of 6 (1,526 Views)
08-28-2011 09:35 AM in reply to: JDMather
Or use the old "pre-HELIX" method - the SPIRAL command from the 3DSPIRAL AutoLISP utility. See:
http://www.cadstudio.cz/download?file=Spiral
Vladimir Michl, http://www.cadforum.cz
Member
kahmeng_tan
Message 6 of 6 (1,521 Views)
08-28-2011 03:59 PM in reply to: JDMather
Yes I used the helix command, specified inner and outer radius, used 0 as the height, and flatten to convert into a polyline.
