AutoCAD 2010/2011/2012
Distinguished Contributor
oyy5408
Message 1 of 8 (2,562 Views)
Hatching does not work AT ALL. Help needed!
2562 Views, 7 Replies
05-28-2010 07:10 PM
On a drawing I was working on, (not big at all, 556kb)
I needed to do some hatching, and tried, but failed.
So I drew a small simple rectangle in the same drawing file and tried, but failed once again.
Opened up a new document and tried hatching in a rectangle, worked fine.
I copied everything into the new document I've opened up (with the working hatching), and tried hatching again into a small rectangle, but failed.
"Selecting everything visible...
Analyzing the selected data..."
that's all it gives me and after awhile it just says it couldn't do it and suggests me to zoom out or sth, giving me all unhelpful tips.
I'm using
Macbook Pro
Windows XP Service Pack 3,
Intel C2D 8700 2.53GHz
4GB ram (but with xp sp3, maximum is 3gb)
NVIDIA Geforce 9400M, newest update.
Lots of hard disk space. (+100gb)
This is frustrating. Autodesk seems to fail in making hatch works perfectly fine ever since. (upto AutoCAD 2011 at least)
Also, as I am very short on time, I would like to politely refuse to receive comments regarding running windows on mac using bootcamp, because this is not the solution. It worked fine before, it works fine on my imac, and my friends' macbookpro.
*UPDATE
Object option works fine. Edited by: oyy5408 on May 29, 2010 2:11 AM
*None
Message 2 of 8 (2,562 Views)
Re: Hatching does not work AT ALL. Help needed!
05-29-2010 07:14 AM in reply to: oyy5408
> I'm using
> Macbook Pro
> *UPDATE
Wblock your dwg and insert into new dwg and THEN try hatching.
oyy5408
Message 3 of 8 (2,562 Views)
05-29-2010 07:33 AM in reply to: oyy5408
I tried as you suggested. It didn't work.
Same error(?) messages.
I'm actually quite glad it didn't work because this is definitely not the method I would like to use whenever I need to do hatching.
I tried hatching it in 2011, and it worked although it was incredibly slow in 'analyzing' the boundaries. (1~2 min per clicking in side boundary. But works.)
This is beyond annoying.
*None
Message 4 of 8 (2,562 Views)
05-29-2010 01:26 PM in reply to: oyy5408
Sound like there is a problem with the boundary. Perhaps not at the same
Z elev?
oyy5408
Message 5 of 8 (2,562 Views)
05-29-2010 05:10 PM in reply to: oyy5408
All the objects in the drawing are confirmed to have 'zero' as z-value
Active Contributor
paulgian_01
Message 6 of 8 (2,562 Views)
05-29-2010 08:35 PM in reply to: oyy5408
try using "select objects" instead of "pick points"
*jg
Message 7 of 8 (2,562 Views)
06-01-2010 06:57 AM in reply to: oyy5408
1) Try hiding irrelevant layers, for example if hatching walls, hide
furniture, doors, windows etc.
2) Set hpgaptol higher
Valued Mentor
Randy_Culp
Message 8 of 8 (2,562 Views)
06-01-2010 11:57 AM in reply to: oyy5408
post the file
