AutoCAD 2010/2011/2012
Member
Rogerv
Message 1 of 3 (191 Views)
Hatching displayed differently
191 Views, 2 Replies
11-19-2012 07:27 AM
I am working with Autocad 2011 and I have a problem with the geometry display. The block I created was a dynamic block of a concrete nail we use in surveying. The circle is created with two lines crisscrossing each other so as to create 4 quadrants within it. I also created it with visibility states and a lookup parameter for scaling to the appropriate size according to the drawing scale. The visibility state is for "Found state" and a "Placed state". For the found state 2 of the 4 quadrants are filled in(using a hatch pattern) and for the placed state all 4 quadrants are cleared. What is happening is the hatch pattern is changing to different quadrants of the circle depending on what scale you chose from the lookup scale list. Hope this is understandable and can anyone help me?
Product Support
Dan.Scales
Message 2 of 3 (131 Views)
Re: Hatching displayed differently
11-23-2012 09:43 AM in reply to: Rogerv
Try using an X-Y scale parameter rather than a linear parameter:
I tested this and it works fine for me.
See attached block.
Dan
Dan Scales
Member
Rogerv
Message 3 of 3 (124 Views)
11-23-2012 10:33 AM in reply to: Dan.Scales
Thanks. I will try that and possibly that is what I will need for similar blocks that we use in our industry. Roger Violette, C.S.T. 831924 Alberta Ltd. 2403 - 52nd Avenue S.W. Calgary, Alberta T3E 1K5 Phone: 403-264-5927; 403-852-9711(Cell) roger.violette@shaw.ca
Announcements
Need installation help?
