AutoCAD 2010/2011/2012
JasonRuhl
Message 1 of 10 (438 Views)
Hatching conflicts with multileaders
438 Views, 9 Replies
11-28-2011 09:34 AM
Hi;
Running ACad 2012 SP1 on Win 7/64 bit.
NVidia GEForce GTX 465 video card
Attempting to hatch (walls, in this case). This screenshot is just after I enter the Hatch command...
... And this is what happens when I click inside the wall to be hatched. This is the exact same sceen, one mouse click later:
... This seems to be my green text somehow suddenly expanding in size. This then prevents the hatch from being properly applied. THe green text is all annotative, seems to be MLeader, and also happens when I have an MLeader with a block / attirbute (ie, in the first image I have a "W6" block in a diamond multileader.
To avoid this I have been usind Layiso / Layuniso but this takes time & doesn't automatically 'cut out' the hatch if there is text in the way.
Any ideas?
Hi Jason,
Sorry for the late reply.
The Assemblytype and Millworkfinish blocks have annotative attributes, and the Materialtype does not have an annotative attribute.
If you open those 2 blocks in the block editor you will be able to set the attributes to non-annotative in the Properties palette.
Hopefully this will help you, please let us know.
Cheers,
Luciane
Product Support
luconceicao
Message 2 of 10 (412 Views)
Re: Hatching conflicts with multileaders
11-30-2011 06:06 AM in reply to: JasonRuhl
Hi Jason,
Does this issue happen only with this file?
Can you upload the file so that we can have a look?
Cheers,
Luciane
Luciane Conceição
Product Support Specialist
JasonRuhl
Message 3 of 10 (403 Views)
11-30-2011 11:04 PM in reply to: JasonRuhl
Hi Luciane;
The problem seems to occur on most of the files that I work on; I may not always notice it as I try to draw, hatch, then annotate (sometimes clients change their minds though :-)
I have attached the particular file that I took the screen shot of, and also my blank template file (imperial). Note that I am also using a specific font (Bell Gothic) for my text and am wondering if this may be part of the problem.
Thanks;
Jason
Product Support
luconceicao
Message 4 of 10 (401 Views)
12-01-2011 07:10 AM in reply to: JasonRuhl
Hi Jason,
I am a bit busy today and won't have the time to look into your files in detail but this is related to the annotation scale.
If you set the drawing annotation scale to 1:1 then the issue does not happen.
I changed the font to arial and the issue persists (as it is filled).
You can also freeze the multileader layer as another workaround.
When I have more time I get back to you.
Cheers,
Luciane
Luciane Conceição
Product Support
luconceicao
Message 5 of 10 (382 Views)
12-07-2011 09:10 AM in reply to: JasonRuhl
Hi Jason,
I could not find the culprit, sorry.
Are you able to reproduce this from scratch?
I can send the file to our developers. How many files are affected?
Did the workaround of setting the annotation scale to 1:1 help you?
Cheers,
Luciane
JasonRuhl
Message 6 of 10 (361 Views)
12-09-2011 07:39 AM in reply to: JasonRuhl
Hi Again Luciane;
The attached file is new (with my default settings, etc.) and I  have isolated the problem a bit more: It happens only with multileaders that have blocks (ie, my wall type diamond).
If I insert the (non-annotative) wall type diamond block on its own, then the text will resize itself to the active anno scale.
This happens with the Millwork ID Mleader style, and the Assembly type Mleader style, but not the Material type Mleader style. When I insert those blocks on their own (ie, not as a multileader), only the Material Type block behaves properly.
The blocks (all 3) use the same text style too, so I'm quite confused by this.
So for now I am continuing to eithey Layfrz or change the annoscale to 1:1.
Thank you for looking into this.
Jason
Product Support
luconceicao
Message 7 of 10 (341 Views)
12-13-2011 08:02 AM in reply to: JasonRuhl
Hi Jason,
Cheers,
Luciane
Product Support
luconceicao
Message 8 of 10 (320 Views)
01-16-2012 07:36 AM in reply to: JasonRuhl
Hi Jason,
Were you able to set the attributes to non-annotative in the Properties palette?
Did that work?
Cheers,
Luciane
JasonRuhl
Message 9 of 10 (298 Views)
01-24-2012 09:09 PM in reply to: luconceicao
Hi Luciane, yes, I made the modification to my template file and it hasn't been a problem (with new files) since. Thanks!
Product Support
luconceicao
Message 10 of 10 (278 Views)
01-25-2012 09:30 AM in reply to: JasonRuhl
Great, thanks for the update :smileyhappy:
