AutoCAD Forum
hatch issue
10 REPLIES 10
Message 1 of 11
rochesterdragon
295 Views, 10 Replies
hatch issue
when i try to open hatch on my computer with autocad 12 and 14. it trys to open a drawing from file then it crashes can someone help me please
10 REPLIES 10
Message 2 of 11
pendean
in reply to: rochesterdragon
Do you mean it crashes when you start HATCH command?
Does this happen in ALL files, or just one or a few?
Even if you start a new file?
Is this a new problem, or has always happened?
Message 3 of 11
rochesterdragon
in reply to: pendean
yes it craches in all files.  befroe it crashe sometimess it goes to the open new draing from the folder the drawing is kept in.  this problem is the same on both versions of cad im running on this computer.
thanks
Message 4 of 11
Did you add or change a Hatch pattern recently?
Or open and do something inside the *.PAT file?
Though unless you are using the same PAT file for both Versions this would not affect across both the 2012 and 2014.
Message 5 of 11
i have not it not juat crashes i have tried on a differnt drawing same issue
Message 6 of 11
One particular pattern or any?
Custom or OOTB pattern?
Can you post a sample file that exiibits this behavior?
Have you tried to WBLOCK a file that is exhibiting this crash? AUDIT perhaps? Or RECOVER to open the File that crashed after it crashed?
Message 7 of 11
its when i try a new hatch instead of opening the hatch panel it crashes
thanks for trying to help
Message 8 of 11
To me that sounds like a bad definition in the Hatch Pattern file but would be unusual across two versions.
Message 9 of 11
Could it be an installation issue
Sent from my iPhone
Message 10 of 11
Message 11 of 11
Will do tomoz
Sent from my iPhone
”Boost
