AutoCAD 2010/2011/2012
0 Kudos
Post 1 of 11
Grid in layout view
6160 Views, 10 Replies
05-21-2010 06:00 AM
I received a drawing that has a layout with multiple mviews in it. There is a light grey grid showing in the layout, that I can't make disappear. Grid on / off command has no effect. Really it doesn't matter if the grid is showing, but it's so annoying! Creating a new layout would fix the problem, but is there an easier way to get rid of the grid?
Double-click inside the viewport to make it active, and then press F7.
Any change?
Silvia
Silvia Menon
Autodesk Product Support
*Dean Saadallah
Post 2 of 11
Re: Grid in layout view
05-21-2010 06:09 AM in reply to: hmsuunnittelu
AUDIT or RECOVER commands to fix the file, see if that helps, or use SAVEAS
to create a new file, delete all private info and post the DWG file here.
Or just create a new layout as you noted.
Dean Saadallah
http://LTisACAD.blogspot.com
*Pro
29 Kudos
Post 3 of 11
05-21-2010 07:10 AM in reply to: hmsuunnittelu
...or write the whole thing off as a block. Or create a new drawning and copybase the entire contents of old into new...
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
213 Kudos
Post 4 of 11
05-21-2010 07:13 AM in reply to: hmsuunnittelu
Make that VP current and then turn grid off.
If something I wrote can be interpreted two ways, and one of the ways makes you sad or angry, I meant the other one.
0 Kudos
Post 5 of 11
06-22-2010 03:32 AM in reply to: GrantsPirate
Last time I just ended up creating a new layout, but this problem seems to come up repeatedly. It seems that if the layout has been created with the grid on in the model space, it will also show in the layout.
I don't know how to "make the VP current and then turn grid off", so further advice would be welcome.
Other suggestions would also be appreciated.
Valued Contributor
4 Kudos
Post 6 of 11
06-22-2010 10:37 AM in reply to: hmsuunnittelu
Old school, no ribbon: Tools -> Drafting Settings -> Snap and Greed -> Greed style: uncheck Sheet/layout and, of course, press F7 for greed On/Off
0 Kudos
Post 7 of 11
06-23-2010 12:12 AM in reply to: nikolap
Changing drafting settings has no effect on the problem...
Product Support
25 Kudos
Post 8 of 11
06-23-2010 01:22 AM in reply to: hmsuunnittelu
Any change?
Silvia
Silvia Menon
0 Kudos
Post 9 of 11
06-23-2010 01:35 AM in reply to: Silvia.Menon
Thank you so much! I don't know how I didn't think of something that simple.:smileyvery-happy:
New Member
0 Kudos
Post 10 of 11
10-24-2011 02:37 PM in reply to: hmsuunnittelu
Thanks a lot.. I was trying to figure out the same thing... your post was very helpfull!! 'Thumbs up'
